Need some technical assistance and/or contacts on a 04’ Brute 750 (1400 miles well maintained). While riding at the dunes engine started making noise, quickly let off to idle then locked up. Removed hand recoil starter and was able to move engine some. Removed front spark plug and valve covers. No issues with valves and there is compression although could not totally rotate engine.
Rear cylinder removed plug and noticed something hasdbent electrode. Valve covers removed and does not appear to be any issue with valves. While rotating engine gentle back and forth finally could be turned over full revolution. Rear cylinder does not appear to have any compression.
Any thoughts on next steps if I decide to tear into it???
Any technicians online that moonlight in southern Michigan or have contacts that might?
Thanks
Tom
Thanks
Tom
