Here we go guys and gals. I cant find anybody on my list waiting for one of these kits, so here it is available first come first serve.
Its a 330 kit, that bolts straight onto a stock rod and bottom end. No mods are necessary to slap this sucker on. The port timing has been set up for all around use. Good low end, with lots of power up top.
Kit includes:
-Cylinder freshly nickasil plated
-Modified piston
-Newly designed Sprock billet cool-head with o-ring design
-o-rings
-dome size of your choice. High compression (race fuel) medium (race mix) low (pump gas)
-acorn nuts, and brass washers to seal everything up.
-base gasket
Piston is not pictured, forgot to throw it down when I was taking the pictures earlier.
$600 shipped to your door. All products come with a satisfaction money back guarantee. If your not satisfied with what you get, send it back for a full refund.
These kits are tried and true, the same kits Corey has produced for years. There will be more available shortly. This has been on the shelf for a little bit, want to get it in somebody elses hands that will use it.
No power valves included. You will need to supply your own. Our plating company usually cleans these up really nice, but for whatever reason this one came back with a little bit of paint. For no extra charge I will put a coat of high temp PJ black engine paint on. Otherwise, this is what you get.
Thanks, call with any questions. I also accept credit cards along with paypal if interested.
