I have a 91 Bayou klf 300 4X4 that will not start. When trying to start the starter will try to turn over but then sound like it locks up and grinds. When I hold up lever, not sure what lever is, on right side of motor the starter will turn continusly. When I pull the spark plug to check fire, the plug only sparks at first press of starter and when I let off starter. Any help is greatly appreciated. I am verry new to the atv scene so it is ok to assume I am an idiot.
it sounds like a week baterie i had the same problem i hooked it up to a 12 volt baterie charger and put it to a jump seting and let it sit for amout 5min my started right up. also try a e3 spark plug.
I tried starting the bike while hooked to a car battery, not hooked up in a car, but did not do anything. I will try the new spark plug and see what happens.
if its a manule try geting it up a hill and put in 2nd or 3rd gear and hold down the cluch, then let it pick up speed then drop the cluch.
