Background info first. A few months ago I bought a 91 Bayou 300 4x4 very cheap, it needed a piston and I swapped a good condition used cylinder/piston set from a parts bike. Also cleaned the carb, adjusted valves, oil change, new battery, etc. The bike has good compression cold or warm (around 140), starts very easy (1 pull, never need the e-start) ran great, went on several 3-4 hour rides, and almost daily use around the yard. The only issue was it would idle low when cold and very high when hot.
The last several times I've tried to use the bike it will run as good as always for 5 - 10 mins until it's completely warmed up and then it won't rev up. Idles well, but if I push the throttle it sounds like I'm hitting a rev limiter at low rpm. Also if I hold wide open for a few seconds, when I back off it revs higher than it would with throttle for a second or two then idles down.
Any suggestions where I should start?
Thanks in advance.
Thanks in advance.
