I flipped my 96 lakota yesterday and the only thing that git hurt as far as I can tell us the handlebars. So I'm looking for something on the aftermarket or maybe a good oem set but can't find anything that says direct fit. Any suggestions? Also just ordered a caltric centrifugal clutch kit and a vesrah heavy duty secondary clutch kit with discs friction plates and heavy duty springs, also a k&n oil filter for it as well. Any suggestions or tips before I do this? Any help is appreciated!
Google p/n 46003-1571-5A for the handlebars it will get you more results.
For the clutch job make sure you get a side cover gasket for it.
And be sure to clean the lil screen in the bottom of the motor while you have the side cover off.
Thank you sir! And yes I forgot to clean the screen on the last oil change so I'm sure it needs it.
