I sent you an email.
I was told to install stronger springs, have to get them first then try it. someone else told me to only use motorcycle/atv oil. dont think that makes a difference, I use 15w40(diesel engine oil) in everything because of the super high detergents needed for diesels and they hold up to high temps because most diesels are turbos. If anything my klr650 sometimes the clutch wont slip when first started.
It must have gotten held up. It shows sent.
Yes Oil will make a difference. If you are not using oil designed for a wet clutch system it will ruin a clutch. The plates will glaze up fast due to no friction inhibitors in the oil. Then it will slip to the point it puts a strain on the centrifugal and basket and will begin to groove the basket, to the point the plates will bind in the grooves. Thus the reason your clutch is probably hanging at start up, the plates are prolly in a groove and not floating. There is a reason that the manual states" Use only oils designed for motorcycles and atvs".
