1 - 7 of 7 Posts
hey, im new here, was reading about the popular 12 hole mod. well i tried that but it does not run right at all. i have dual yosh, uni filter, 8mm spark plug wires and different boots. bigger jets. it runs ok after i put the pipes on but i was expecting different results i guess you could say...any help would be great.
Discussion Starter #6
ok..well i did rejet after i put the pipes on. i pulled the plugs and they look perfect. what it does is at idle it putts a bit, and kinda hard to start, i havent messed with the air/fuel screw yet, ill do that this weekend. thanks for the welcome. you guys have some sick 700's.
Discussion Starter #7
i put some bigger jets in and turned the screws out, the only problem is i would think the 180 jets are a little big, stock is only like 135f 140r. idk thanks for the help guys and how much of the spring do i cut off?
1 - 7 of 7 Posts
