1 - 20 of 87 Posts
Fired her up at 10:15 local and sounds like a V-8. Did the cam break-in, tomorrow will be the fun part. Oil change check the jetting and haul azz.
Thanks Glenn and Kev for all the help getting her going. Took the cam weights off and sounds awesome no more clickety click. :lol::lol:
There's always that short moment before you push the button... dead silence.
Removed the cam weights? Did you weld up the decomps? What?
Yes they are welded. The moment of truth is always exciting this was just my second build. I'm more of a helper not the mechanic. We started at 2:30 so took 8 hrs with a few OH SHIZ forgot that.
can't wait for some ride impressions
congrads minimus... so you went from a standard bore 750 to a 840.. :D you will definitely feel the rush then.... enjoy it..:cool:
sweet, congrats.
Congrats..
Now go make some vids:)
Congrats...that is always a very exciting time between getting it to start the first time after the bbk installation and actually riding it!
No kidding..
The moment before the first time you hit the starter button after a rebuild is very emotional:cool:
It's almost like having sex when it first starts:wub:
:tup:Glad to hear you got her going...
those cams love high rpm's, the better you can get it to breathe, they just keep building power
looks good , building fast rpms...like to see someone shift that fast..lol..jh
Discussion Starter #15
If I took this same bike down to sea level I would be pushing 9000 RPMs in 300' 70 mph range I think. I was 65 mph on speedo at 4,300'. Very impressive with a 20% power loss for elevation. Will be interesting what it does on nos. :D
If? But you're not a sea level.
What rpm's are you at now?
Discussion Starter #17 (Edited)
8,150 in 300' run.
Try 4 v-force weights. You can also lay them down on the belt sander to lighten them up a little more. That clutch of yours will still perform with the lighter weights and give good belt grip. Then you'll get more rpm and sounds like your cams would like that better anyways. :tup:
pretty impressive MPH
what CDI are you using?
Congratulations on the build minimus.
I was curious so I googled the elevation for the town of St. Anthony. It is 4972
1 - 20 of 87 Posts
