1 - 10 of 10 Posts
looking for some plans to build my own audiopipe. texasbowhunters has some plans but does anyone have any experience building their own? should i run off a seperate battery or just throught the cig outlet plug? thanx in advance.
cigarette outlet is fine... They arent hard to build.. I have a friend that has made a couple and if he can do it.. it cant be hard!! LOL
look pretty simple. there is one that goes on the back rack made out of a tool box that i'm looking to build, the split tube design is cool also. i have my gun racks on the front so whatever i build can't interfere with that.
Im in the process of building a 6" audio tube. I'll take some pics once I get all my parts togather. I just ordered a pyramid 2 channel amp that should not draw more than 5 amps (according to the factory specs). I was told the fuse for the 12V accessory plug was 10 amp, so that should be plenty (im gonna double check next time I get to ride).
does anyone have pics of the split tube design? I've never heard of them and curious if it would be better than the normal audio pipe...
Discussion Starter · #8 ·
oh, i forgot that i would post pics. i'll take some this afternoon, going out after some coyotes here in about an hour. it turned out great! sounds very good although i will have to take the amp side apart as i turned the gain all the way up without testing..duh, and it will sound better at 3/4. on all the wires that run out of the main tube, i used quick release bullet connectors. makes it a lot easier to take them on and off. pics later. got a video also
i built mine. i used the paramid amp. polk marine speakers.cigarette lighter plug for power.a rca jack cable to plug player to.i got i think 150.00 in mineit was simple to build. on highlifter on accesories they have a link about building and pics it older but you can find it
Discussion Starter · #10 ·
see pics on other thread of mine, BOSS amp as the pyramid i had for 2 days shorted out!!! the BOSS amp is working fine. took it out for a 2 hour ride today and realized i had the amp gain set to max volume and it sounded like crap. when i changed the amps i went ahead and put quick releases on all the wires and it was sooooo easy to get in there and turn the gain down to 3/4. 2 screws holding the amp to the wood support and the 4 screws for the speaker. do yourself a favor and use bullet connectors if you are going to build one, you will thank yourself when you have to change a fuse!!!!!
1 - 10 of 10 Posts
