I still need a pipe - either stock or aftermarket for my mock up - so I'd prefer it to be cheap. It doesn't have to be in great shape, as long as it's not bent.
I was also wondering if the tecate has an exhaust flange or if it just bolts directly into the motor?
it spring mounts directly to the head. i have several pipes, fmf and stock either one complete is 65.00 shipped.
Is there any weight savings to the FMF and is it exactly the same bends as a stock pipe?
If somebody had to modify one - cut it in half to be be mounted and use as a template to build a custom pipe - which would be the one to go with?
Do you have any pictures of the pipes or of them side by side with other makes like the ILR or Powerpros?
This is obviously for my Tecate motor in a KFX450 project. I think it will be pretty good, but the pipe is really the only issue.
If your goin to cut one up use an fmf
