I have a '04 Vforce with brute force 750 engine cases. Will a top end gasket kit for the Vforce work? The jugs are from a Vforce so I know Vforce head gaskets will work, but what about the base gasket?
Vendor
yes, run the Vforce base gasket it is wider/thicker to the cylinder than the brute, but the brute will work as well. they are both the same thickness so it doesn't matter either way. but the V base gasket is a better fit for the V cylinders.
:tup:
