hello all, on the front cylinder right behind the stater i noticed the base gasket seems to be weep some fluid. it should be coolant but seems oily, only thing i can think of is possibly oil from the stator wires as that rubber plug on mine does leak a little.. im really dreading the idea of tearing the motor down for some thing so little..
Mine just has a spot at the bottom of the base gasket next to the 8mm bolt on the right side of the front cylinder where it looks a little oily, but dont affect anything.
