ok guys i'm stumped with this dang carb! problem is that when you cut the motor off, it leaks gas outa the little nipple on the bottom of the carb bowel! its not the bowel drain its the one with the rubber hose conected to it that runs down! i have taken the carb apart and cleaned everthing and put back togather! fixed it for one day then it started rite back!! i think whats happening is the bowl is over filling and running outa this overflow! any ideas? thanks
bayou carb
I have had 3 bayous and 1 prairie do the same thing. I have cleaned the carbs and fixed it for a while. I started replacing the plastic float and the needle. Make sure the rubber on the end of the needle dosen't come off and get stuck in the carb. The plastic float seems to bend over time and the float level is off. Just my experiance.
float valve.......
Might need a new float valve.......if its damaged or indented replace it ........adjust the float if needed so it don't flood.................
