1 - 11 of 11 Posts
i took the time :)confused:) to put together a list of all the bbk engine sizes that i could figure up. i realize that some of these engine combos are only hypothetical so be easy on the comments, also note that in some instances there are multiple ways to get the same displacement. this list was intended to be used as a reference only.
* i got all my information on the crank and piston sizes from the forum, so if any dimension is wrong then i apologize but i was only working from what i saw posted on different threads, so basically if its on this list then i saw that dimension SOMEWHERE on the forum. :D the different colored sections are catagorized by different crank sizes, then starting from the smallest availible piston size and working to the largest i could find i listed the different engine combinations. enjoy
Volume of a cylinder = pi r2 h x2 ( number of cylinders )
Type 1 crank from 650 = 63mm
Type 2 crank from 700 and 750 cc motors = 66mm
Type 3 crank from bbk = 72mm
Type 4 crank from bbk = 73.5mm
650 stock cylinders=80mm
700 stock cylinders=82mm
750 stock cylinders=85mm
Piston sizes:
80mm 81mm 82mm 83mm 84mm 85mm 86mm 87mm 88mm 89mm
90mm 91mm 92mm 93mm 94mm 95mm
Stock 650 pistons and type 1 crank (63mm) (3.14 x ( 40^2mm ) x 63mm) x2 = 633cc
80mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14 x ( 40.5^2mm ) x 63mm) x2 =650cc
81mm pistons with type 1 crank
650 with bored cylinders and stock crank ( 3.14 x ( 41^2mm ) x 63mm) x2 = 665cc
82mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14 x ( 41.5^2mm ) x 63mm) x2= 680cc
83mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14 x ( 42^2mm ) x 63mm) x2 = 700cc
84mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14 x (42.5^2mm ) x 63mm) x2 = 715cc
85mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14 x(43^2mm ) x 63mm) x2 = 730cc
86mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14x(43.5^2mm ) x 63mm) x2 = 750cc
87mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14 x(44^2mm ) x 63mm) x2 = 765cc
88mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14x(44.5^2mm) x 63mm) x2= 785cc
89mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14x(45^2mm) x63mm ) x2 = 800cc
90mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14x(45.5^2mm)x63mm)x2 = 820cc
91mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14x(46^2mm) x 63mm ) x2 = 840cc
92mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14x(46.5^2mm)x63mm)x2 = 855cc
93mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14x(47^2mm)x63mm)x2 = 875cc
94mm pistons with type 1 crank
650 with bored cylinders and stock crank (3.14x(47.5^2mm)x63mm) x2 = 895cc
95mm pistons with type 1 crank
700 with SMALLER cylinders and stock crank (3.14x(40^2mm) x66mm) x2 = 665cc
80mm pistons with type 2 crank
700 with SMALLER cylinders and stock crank (3.14x(40.5^2mm)x66mm) x2 = 680cc
81mm pistons with type 2 crank
Stock kfx 700 or prairie 700 with type 2 crank (66mm) ( 3.14 x ( 41^2mm ) x 66mm) x2 = 700cc
650 with bored cylinders and kfx 700 crank 82mm pistons with type 2 crank
700 with bored cylinders and 700 crank (3.14 x ( 41.5^2mm ) x 66mm) x2 =715cc
83mm pistons with type 2 crank
700 with bored cylinders and 700 crank (3.14 x ( 42^2mm ) x 66mm) x2 = 730cc
84mm pistons with type 2 crank
Stock brute force 750 with type 2 crank (3.14 x ( 42.5^2mm ) x 66mm) x2 =750cc
85mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14 x( 43^2mm ) x 66mm) x 2 =765cc
86mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14 x( 43.5^2mm ) x 66mm) x 2 =785cc
87mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14 x ( 44^2mm ) x 66mm) x 2 = 800cc
88mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14x ( 44.5^2mm ) x 66mm) x2 = 820cc
89mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14x( 45^2mm ) x 66mm) x2 = 840cc
90mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14x(45.5^2mm ) x 66mm) x2 = 860cc
91mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14x(46^2mm ) x 66mm) x2 = 875cc
92mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14x( 46.5^mm ) x 66mm) x2 = 895cc
93mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14x(47^2mm) x 66mm ) x2 = 915cc
94mm pistons with type 2 crank
750 with bored cylinders and stock crank (3.14x( 47.5^2mm)x66mm)x2 = 935cc
95mm pistons with type 2 crank
750 with SMALLER cylinders and stroker crank (3.14 x (40^2mm) x 72mm) x2 = 725cc
80mm pistons with type 3 crank
750 with SMALLER cylinders and stroker crank (3.14x( 40.5^2mm)x72mm) x2 = 740cc
81mm pistons with type 3 crank
750 with SMALLER cylinders and stroker crank (3.14x( 41^2mm ) x 72mm) x 2 = 760cc
82mm pistons with type 3 crank
750 with SMALLER cylinders and stroker crank (3.14x(41.5^2mm) x 72mm)x2 = 780cc
83mm pistons with type 3 crank
750 with SMALLER cylinders and stroker crank (3.14x( 42^2mm )x 72mm ) x2 = 800cc
84mm pistons with type 3 crank
750 with stock cylinders and stroker crank (3.14x(42.5^2mm)x72mm) x2 = 820cc
85mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14x ( 43^2mm ) x 72mm ) x2 = 835cc
86mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14x(43.5^2mm)x 72mm ) x 2 = 855cc
87mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14 x ( 44^2mm ) x 72mm ) x2 = 875cc
88mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14x( 44.5^mm ) x 72mm) x2 = 900cc
89mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14x(45^2mm ) x 72mm) x2 = 915cc
90mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14x(45.5^2mm ) x 72mm) x2 = 935cc
91mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14x(46^2mm ) x 72mm) x2 = 960cc
92mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14x(46.5^mm ) x 72mm) x2 = 980cc
93mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14x(47^2mm) x 72mm) x2 = 1000cc
94mm pistons with type 3 crank
750 with bored cylinders and stroker crank (3.14x(47.5^2mm)x72mm)x2 = 1020cc
95mm pistons with type 3 crank
750 with SMALLER cylinders and stroker crank (3.14x (40^2mm)73.5mm) x2 = 740cc
80mm pistons with type 4 crank
750 with SMALLER cylinders and stroker crank (3.14x(40.5^2mm)73.5mm)x2 = 760cc
81mm pistons with type 4 crank
750 with SMALLER cylinders and stroker crank (3.14x(41^2mm)73.5mm ) x2 = 775cc
82mm pistons with type 4 crank
750 with SMALLER cylinders and stroker crank (3.14x(41.5^2mm)73.5mm) x2 = 795cc
83mm pistons with type 4 crank
750 with SMALLER cylinders and stroker crank (3.14x(42^2mm ) x 73.5mm)x2 = 815cc
84mm pistons with type 4 crank
750 with stock cylinders and stroker crank (3.14x(42.5^2mm)x73.5mm) x 2 = 835cc
85mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x(43^2mm) x 73.5mm ) x 2 = 855cc
86mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x(43.5^2mm)x73.5mm)x2= 875cc
87mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x(44^2mm) x 73.5mm ) x 2= 895cc
88mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x(44.5^2mm)x73.5mm)x2 = 915cc
89mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x(45^2mm ) x 73.5mm) x2 = 935cc
90mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x(45.5^2mm) x 73.5mm) x2 = 955cc
91mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x(46^2mm) x 73.5mm) x2 = 975cc
92mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x(46.5^mm ) x 73.5mm)x2 = 1000cc
93mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x (47^2mm ) x 73.5mm) x 2 = 1020cc
94mm pistons with type 4 crank
750 with bored cylinders and stroker crank (3.14x(47.5^2mm)x73.5mm)x2= 1040cc
95mm pistons with type 4 crank
That's a lot of work. Thanks, I'm sure the information will be useful.
Dam you have me all confused on what I have.
That took a crap load of time to make,nice job.
This should be pinned.
sorry bout that skip :D, it looks alot cleaner on my original copy here at the house. forum wouldnt let me attach a microsoft word document, so i had to copy and paste the whole thing.:rolleyes:
yea glad you guys see how much work went into making this thing. lost count of the hours after the third night staying up til 2:30 a.m.
The funny part to me is, I don't even know if the info is correct:lol: but I'm impressed with the time you put into it:clap:
Discussion Starter #8
good job bud....that should a sticky...
:rolleyes: hint...hint administrators. this could clear up alot of questions that newbies have about bbks.........................or just create more questions:(
Why is there only a couple of them shown for the 700cc with over bore? I only see 715 & 730?
Discussion Starter #10 (Edited)
because im assuming that for anything over those bores ( using the 66mm crank ) you would just use brute 750 cylinders. both the 700s and the 750s have the same crank size so you reach a point on the bore where your 700 would run into and become a 750. also bear in mind that im not entirely sure how far you can bore 700 cylinders before you need to re-sleeve them.
agree!!
can only imagine the hrs that went into all that info!!
thanx!!:D
1 - 11 of 11 Posts
