1 - 7 of 7 Posts
Belt light just came on yesterday. Checked the intake and exhaust and they do not seem to be blocked. Also the belt cover is not hot. What could be the issue?
the first 100 hrs the belt light will come on for service and after that when ever the belt is out of spec
the belt light will come on around the 100 hr mark,and every 100 hrs from the last reset.
ok cool. I just his 109hrs. Is it really time for a belt change? Or can I just reset the light and keep going.
The belt light has nothing to do with heat. It either has timed out, as others pointed out to you, or the belt is very loose or beginning to shred and has tripped the "broken belt" inside the clutch/belt cover.
If you feel the belt is good, then do nothing other than just doing the belt switch reset. It's not a bad idea to pull off the belt cover and inspect the belt though, just in case.
Discussion Starter #6
o.k ill do that. But how do you do a belt switch reset?
It's covered hundreds of times in the forum. Try the search function.
1 - 7 of 7 Posts
