1 - 11 of 11 Posts
Dont think so cause the 750 runs a bigger piston pin. My 03 KX 250 we used a JS650 rod to make it into a longrod motor. The upper an lower bearing sizes match the stock ones. That way all we had to do was get a spacer plate for the cylinder. Cometic cut one out for us, I think it was only like $20.00 back then.
I just looked up the peices on the Wiseco website and the 750 runs a 22mm piston pin and the 650 runs a 18mm pin. Which is the same size as the Tecate an all other KX250's for the most part.
1 - 11 of 11 Posts
