Blank LCD screen on speedo
5397 Views 5 Replies 5 Participants Last post by  riverkid
I have a 2002 Kawasaki Prairie 650 I'm working on and my problem is that I get nothing on the LCD display. With the key on or when it's driving it's just a blank screen. Where should I look to fix this problem. The only thing that does work is the neutral light. No fuel level, speedometer, or odometer. Thanks for the help.
I dont want to sound like a smartass, but check the wiring. I bought an 02 honda cbr with a "bad" guage cluster, which was LCD. I pulled it all apart and found that it was unpulged.
Have you also checked the fuses?
There are already people who suggested you a lot of things if nothing works show it to good mechanic.
I checked the fuses, and pluged and unpluged the plugs and everything looks in order...Thanks...
Could just be a bad display, I have seen this happen on many hondas. If everything else still works normaly I would say it is just the display. I might have one for sale, Have to make sure it works first.
