1 - 20 of 21 Posts
Taking offers. Costs around $250 new from what I've seen.
Has some wear and tear on it. Bottle will be shipped empty.
I should be having several Boss Noss parts in the near future. I am piecing together a kit for my V.
siphon or gravity
I believe all Boss Noss are siphoned
whats it costing you to piece it together? if you dont mind my asking. id eventually like to get one, i think. either this or the boondockers. whichever is the dummy proof one!
Nothing is dummy proof. I'm living proof.:lol::lol:
Discussion Starter · #6 ·
Not sure. I'm not done yet..depends on what you want. This is a wet kit, Boon is a dry.
all bottles are siphon ,but easy to remove tube ..
A wet kit is more dummy proof then a dry kit. Lots more things can go wrong with a dry kit making your engine will go pop.
ones got a controller that keeps you dialed in at 12.5 afr. thats the one im calling dummy proof. seems safer at least
Vendor
Tanks can be siphon or anti siphon. meaning how do you mount the tank. upside down or standing up. I prefer anti siphon as you get every last bit
shake the tank and see if you hear the pickup inside of it. it'll ring like a bell. easy way to tell. if you hear it. you have the siphon.
Vendor
it's not a controller like that. it's just a pre wired NOS regulated solenoid box that makes install very easy. that's the Boss noss. fuel metering goes with the desired shot in the "jet" you put in the little black nozzle
thats the one!
guess I was thinking and not typing my first set up was siphon,and it was a boss noss set up changed that and relocated bottle and removed the tube ,so I guess they work either way
I have purchased 2 BOSS NOSS 2.5 Bottles. Neither one of them CAME with a siphon tube in them.
Thats most likely because you never asked to have a siphon tube in the bottle ,just depends on placement of bottle either valve up w/ tube or w/ out valve pointing down...
how much does all the other stuff run to install the nitros on a brute??? im needing the "nitros for dummies" myslef.. just wondering cause im gonna put nitros on my bike but i know nothing about it was the parts are or cost etc.. just looking for a good system for a good price.
Discussion Starter · #18 ·
I will be having an EFI controller as well for those putting a boss kit on their Teryx, or Brute..
Discussion Starter · #20 ·
Will trade all around for fst stage 3's or xx cams...or 36's w/ filter....or some aftermarket springs and $$...
1 - 20 of 21 Posts
