Morning all, hope everyone is off to a good start with their day.
about 2 months ago I bought a 95 bayou 300 for a hundred bucks. It was obvious the thing was gonna need some work and I'm up for the challenge. Just looking for some advice on how to get this thing going. The wheeler has an array of problems and I've done a good bit of reading around and learning about the machine lately, but I'm stuck at an impasse and not sure exactly what I need to do to proceed.
So to start with the stuff that was obvious to me; The wheeler has definitely been flipped, the handlebars and steering column are bent, and both front and rear racks were bent and have been cut in places to allow the previous owner to bend them back into a rough idea of what they once were. Along with this the little box on the handlebars with the key and lights was completely missing, The ignition wires were hanging out the side and twisted together and the light wires were just freely hanging down below and were also cut, as they have no bullet connectors on them anymore. to deal with the loss of the reverse lockout they strung a cable through a hole in the plastic and attached a random handle to it.
As a preliminary, I went ahead and purchased an info box complete with key and reverse lockout and a voltage regulator (as I had read they commonly go bad). I have a small question about the ignition wiring, but I will save this for later as this brings us to the actual problem. No matter how good I do at replacing parts such as this, I will never know if any of it has worked because I can't get the transmission to shift at all, but most importantly I can't get it to shift into neutral. I did some research on the problem which consistently lead me to something having to do with the spur gear behind the secondary clutch. I pulled the clutch cover and inspected it, Everything was in place with no loose bolts or anything. I went as far as to remove the spur gear and the levers and springs. I could not find any visual degradation that would lead me to believe this part is the issue. With time running thin in the day I went ahead and put everything back in according to the manual. for a brief moment, I was very excited to find that the shift lever was actually giving me some sort of tactile feedback and felt as if it was shifting, but this was short-lived and it all seemed to jam up and stop doing anything after a few seconds.
When I had the clutch cover off I had my son actuate the shift lever both up and down while I was laying on the ground looking at the spur gear. It seems that every once in a while it was able to grab the spur gear and spin it, but this will ONLY happen if I'm shifting up. It gets completely jammed trying to go down. Occasionally I can get it to spin partially as I am shifting down, but in those situations, it freezes and won't spin any further even if I try to coax it along with a screwdriver. What this feels like on the shift lever is there is no feedback. All I feel is the resistance of the spring and then it hits a spot where it just stops the lever from moving. I get a very distinctive metal on metal "tink" and that's it.
Anyway, this is my big hang-up at the moment. If I can't get the wheeler in neutral I cant test to see if any of the electronics are working, let alone see if it will turn over for me. As a side note, the pull starter is busted, when I pull it I just get the resistance of the spring and it doesn't seem to engage with the motor at all. When the clutch cover was off I grabbed the clutch and spun it clockwise which proved to me that the motor has compression and freely spins.
So that's where I am at now, and I am more or less out of ideas as to what I need to do to either further diagnose the transmission or (fingers crossed) fix it. I figure all the other stuff can wait, as this seems to be the big hinge point on the project at this moment.
I won't be at the farm till later, but when I am I will make a short video of the spur gear so you guys can see firsthand what's going on.
I want to thank you guys in advance for any and all advice you may be able to give me. I am glad to have a resource such as this forum and look forward to hearing from you guys!
Just an update. Turns the reverse lockout lever was gunked up and would pull up to unlock reverse but when it returned it was stopping about halfway before it hit its detent. Seems like this was putting a stop to changing gears at all. I cleaned it up and was immediately able to get the shifter to start doing its thing.
Turns out my purchase was actually a very good one. After being able to finally get it into neutral I got to start digging into the wiring. I don't know what the heck the previous owner was trying to do with the wiring harness in their half-assed attempt to "hot wire" the 4 wheeler. Wires were disconnected, and several wires were connected, but to the wrong thing. Anyway long story short I was able to use the wiring diagram to get things hooked back up the way they were supposed to be. I then installed my new ignition and turned the key. Got neutral and reverse lights.
Now that I was ready to try and start it I had to spend a good bit of time cleaning the fuel system, in specific the tank as it was varnished worse than I have ever seen. Once I cleaned that up I replaced the petcock and was ready to move on to the carb. While I did buy a carb kit, with my fingers crossed I carb cleaned it without replacing anything yet.
put about a gallon of gas in it, turned the key, and hit the start button. This thing didn't skip a beat, I didn't even hear it crank it jumped to life so quickly. It was idling perfect and then it was time for a test drive. Took it around my farm 3 times (very carefully as there are no brakes at the moment) and felt it out.
All and all it runs pretty good aside from needing some carb adjustments (running a bit too rich)
I've got a few more parts on the way to get it buttoned up by all said and done I'm pretty happy. I've got a good running 4-wheeler and only put around $350 into it including the purchase price. My running theory is that when the previous owner flipped it they tried to ghetto rig it into working, but never did. I think this fact kept the motor safe from potential degradation because it was just sitting.
Thanks again for all the suggestions you guys gave me! I hope I can return the favor down the road!
