Turn the crank via the bolt on the magneto side and only turn it clockwise, align the T mark on the TR mark with the mark in the inspection hole then with cam lobes pointed down set the cam in with arrow up and two flat marks at 9 and 3 o'clock, then rotate engine 270 degrees clockwise until the TF mark aligns and repeat with front cam.
Also don't mix up the valve covers
