I have a 2006 BF 650 SRA only mod is cdi. It barely starts and runs. It boggs out really bad. Seems to be popping back through the air box. Put the stock CDI back in and doesn't help. It's full of premium gas. The air cleaner is fine, there is no oil in the cleaner. Took out the front plug and it looked good and dry. There is gas going into the carbs.
I'm having troubles to gt it to start now. I even put a little shot of starting fluid in the carbs and nothing happened. I did get it to run after that though. That's when I put the stock CDI in. Still took alot to get it to start then. I put the trickle charger on it and went baack an hour later and now I can't get it to even fire again.
This morning I rode it to my Parents house and let it idle for a while and when I come out it had died. I restarted it and it idled fine. Went to take off and it would barely spin the tires in reverse on hard pack snow. Took off for home and WOT it would only do about 31 mph.
