Just joined here have a 2007 brute force 750i.
I just bought the bike off a guy who said it was swamped an he just gave up on it I picked the bike up for a stupid low price I cleaned the carbs and changed the oil bike fires right up now its in limp mode due to the belt light I believe. So I took the kebc motor apart to find it full off corrosion and the brushes burnt out this turns me to doing the kebc delete method with the 5 pin relay I followed the kod mod just to try it befor I order the kit to do this properly trying to make sure the bike runs good enough to sink money into it after doing the kod mod I was able to get the belt light to hyper flash in the reset mode I followed the procedure for the reset and nothing the light will not go out I checked another form where a guy had an issue with the belt switch not working so he joined the wires to eliminate it I tried this and no luck the lights still on and flashes slow the bike backfires and will not climb in rpm I have ridden the bike in limp mode to make sure it will move everything seems to work fine all gears just no power cause of limp mode at this point I have no idea what to do with this bike I’d love to get it going for my dad as I have a sportsman 1000 and the girl friend ride a rubicon 500 any insight onto what I should do next would be greatly appreciated thanks for taking the time to read this
Will it shift into 4x4? If it does, it's not in limp mode.
It will not shift into 4x4 it’ was flashing 2wd 4wd before I added the relay now it’s just sitting in 2wd and the display only shows 2wd
That could be wire harness issues or a faulty 4x4 control module under the seat. See if anyone in your area could lend you a 4x4 control module just for testing.
