After a minor rollover my Brute Force 650 is occassionally spitting gas out of one of 4 hoses under the plastic covering the handlebars. I am hoping this is temporary and will settle back after some time. If anyone has any info on this it would be appreciated. Thanks.
It sounds like that you may have trash in one of your carbs causing the needle not to seat off try tapping on the side of both carbs and see if it stops if not you might have to take the carbs apart
