anybody had prblems with these im havn alot of trouble with a cyl cutn out and ive changed everything electrical and carbs and done a leak down and its still there if u bang the throttle its at half rpm if u creep it up its more towards the top of the rpm bike has fst stg2 cams
The decompression weight swing out when your motor starts and they stay out until the motor stops. So if it was your decomps. you would see the problem more at low RPM's. What it sounds like to me is maybe a weak set of valve springs not letting the valves seat properly.
