1 - 15 of 15 Posts
:confused: Can i use a Mobile 1 oil full synthetic oil 0W-40 ????
on 2006 KFX 700
Yes, I used to run it all the time, even in the winter. Never had an oiling issue.
Yes you can I never use anything else! :tup:
Good choice!
Hmmm--0W-40:hmm::hmm:
Kenny
mobil 1's the only oil i buy, but i run 10w-40!
yes you can , but i run something else .
Discussion Starter #10
thank you all for the reply the reason i ask about Mobile 1 (0W-40) this is wot i use in my all Mercedes cars the engine is so clean from in side so i think it should do the same to the bike
so the Mobile 1 10w-40 should be good ?????
Stick with the 0W 40 you'll be fine ;)
some of it is temperature, some of it is just personal preference...I use mobil 1 15-50...
After all the "what kinda oil" threads that have been here, I think as long as you use a good synthetic, and change it regularly, it doesnt really matter what weight oil you use...unless you want something for a specific application.
10w-40 is what the kawi recommends, i wouldnt put 5-20/5-30 like my truck n wifes cx7 call for. its like water, byt new vehicles oil passages are smaller
yes you can!!! :D
1 - 15 of 15 Posts
