2011 Crown Vic here with 305k miles, and today my engine light comes on. Scan at the local Advanced comes up with 4 codes on the cat converter. Guy says I need to get something called Cataclean and run it through the gas tank to correct the problem.
Is it worth doing this...will it make the engine run better or get better gas mileage?
Should I use Cataclean or some other product to get this done?
It's hit or miss. The product does work but if the converters are too far gone, they will need replacement. It's worth a try. Follow the directions to the letter!
Thanks for the input and sorry it took so long to get back. The check engine light went off but it came back on yesterday so I got the codes read again. Guy's machine read 4 codes but said they were all the same code...P0430.
I'm game for the lacquer thinner option I've been hearing about. I see low voc lacquer thinner for sale. Wonder if it matters which version you use?
