I changed the starter gear and the bike started up fine, no leaks. I took it for a 15 min run and it started to leak coolant out of a drain hose that is pretty well centred under the engine. What should I start looking at tomorrow?
The main seal that separates the oil from the engine and coolant has been compromised. It's the one around the waterpump shaft. Order a new one.
Everything went back together fine its when the bike got up to temp the coolant started to come out. I noticed when I shut the bike down. Is it possible the seal is not seated correctly? No place close to get parts.
