When you guys check your oil......
Do you screw the dipstick all the way in, or do you just put the dipstick into the top of the threaded hole and pull out and check the level that way? It makes a difference of about half way on the dipstick level.
All Kawasaki ATV V-twins are the same- that is you screw the dipstick all the way in, then remove it to check it. Not screwing it in.. over fills it.
