1 - 13 of 13 Posts
Hey guys, was just wondering if I needed a clutch kit for 27”-28” Tires, if so what would I need? Thanks
Probably not for a Brute 750. A Brute 650 could benefit from going one or two springs heavier.
I think for 28's you might need a lift kit but im not 100 % shur
I would change springs, without a doubt.
Discussion Starter #10
At least..EPI Pink primary and Almond secondary. If you will be doing a little more in the mud, then I might go with the Maroon primary. Gives a little more stall. The 28s will rub a touch at near full compression but at least not all the time.
I have 1 inch spacers all around, do u think it will still rub?
1 - 13 of 13 Posts
