I pulled the clutch pack off my KFX 400 and left the basket attached. When I pulled the clutch pack off a long thin rod came off with it. The rod is in the middle of the basket.
I re-inserted the rod but is there any special way I need to do it. I did notice there was what appeared to be a keyway in the end of the rod.
I got some help over at suzukicentral on this issue. The rod engages & disengages your clutch.
Push the rod all the way in. Push the lever on the case that attaches to the clutch cable. If the rod pushes out when you move the lever you know you have it correct.
I rode a LTR with a Rekluse. They work very well. I enjoyed it.
