Hi I have a 2008 prairie 360 with a worn out primary clutch , I went to my local dealer to order parts to rebuild it and parts are more money than a new clutch . Does anybody sell rebuild kits? I need rollers, weights, pins, bushings, and shoes. My clutch is in otherwise great shape just the wear parts are wore out.
Nobody sells kits for the wear items of the clutch. vforcejohn can rebuild it for you.
Ok thanks for the quick response, I ended up ordering a cvtech trail bloc clutch hopefully its better than stock.
hi i have a 2015 teryx4 800, i keep blowing up belts, i am running 28 inch swamplites, wondering if you have a clutch kit that i can install that would solve my problem, if so how much money canadian, thanks bob
