what is the stock pressure on a new engine? what is a good - low range? 08 brute 750
L linkage · Registered Joined Nov 19, 2009 · 7 Posts Discussion Starter • #1 • Nov 24, 2009 (Edited) what is the stock pressure on a new engine? what is a good - low range? 08 brute 750
H Hunterworks · Registered Joined Nov 22, 2009 · 1,045 Posts #2 • Nov 25, 2009 It is going to be hard to get yours since there is a decompression mechanism on the cam. You would have to disable it to get a true reading
L linkage · Registered Joined Nov 19, 2009 · 7 Posts Discussion Starter • #3 • Nov 25, 2009 i have readings just wanted to know what was considered bad-great
H Hunterworks · Registered Joined Nov 22, 2009 · 1,045 Posts #4 • Nov 25, 2009 I don't know the exact number but would guess between 120 and 150 If you didn't disable the decompression it will be about 75
Wisconsin 700 · Registered Joined May 25, 2006 · 304 Posts #5 • Nov 26, 2009 The manual for a Prairie 700 says 43-75 psi.
