I hope someone can help. I have been having problems with my cooling system. I am overheating quickly and notice my reservoir is getting hot. I have never messed with a cooling system before. Water pump impellor is working. no fluid leaking. changed thermostat and temp sensor. took thermostat out to see if I could see if I could track down the problem. Radiator is not getting hot. But when hose near fan switch got hot fan came on. any help would be appreciated
Raise the front end as high as you can and see if it'll 'burp'.
Is the radiator plugged up with mud?
