My son just got a 2008 650 Brute. While running it’s leaking coolent from two bolts on the side case above the water pump. We just replaced the gaskets on that side thinking that was the issue but it’s not. Anyone have this issue before? Thank you.
75487
I might be wrong but I don't think those case bolts go through the water jacket at all. Pull one and see though and if it does, use some sealant and reinstall. I think you may find your base cylinder gasket is what's leaking. Check the head bolt torque and if low...it's likely.
