1 - 17 of 17 Posts
Just wondering if anyone has had any experience with these? They are the only 83mm pistons i can find. The ad for them says they are relieved for high lift cams, what cams will work with them.
Thanks in advance
Shane
I do have the cp pistons and I run the amr xx cams, it is a great combo lots of power.
You have a link to where you seen this 83mm CP pistons?
Glenn was using CP pistons originally. he switched to Diamond because CP kept screwing them up
The CP pistons are a decent piece. They are roughly 11.7:1, irregardless what they say they are. The dome is 3.5cc's, and they have .185 pockets. I helped them with the 750 pistons, and they just put the same dome on a smaller piston.
This was their original design, and it hits the edges of a KFX chamber.
Later, they nipped the edges off, and it cleared, but they lost a little volume by doing so.
This was the best they could do for me without going to a Keller molded piston, which are nearly 600 bucks a set dead cost. It's a little taller, and the ears are still taken off, but it wasn't much over 12:1.
This is a $600 dollar Keller molded piston
They make a good product if they care to make it. My problem was, I was always treated like I was too small to matter to them, and I found someone that would give me the time and effort I needed to make things better.
Dawg: I don't think so.
Glenn or anyone else;What the hell is a Keller Molded piston?
We(glenn and I) have talked about them and I just played along like I knew what he was talking about:D
Discussion Starter #12
Thanks guys, I will have to get the link from my buddy again, I seem to have lost it. If they will work with the amr xx cams does that mean they will work with Fundy ultimate trail cams?
Yep, Greg had the last set of the CP's we used.
A keller mold is just CP's term for digitizing a chamber, and reverse imaging that dome on top of a piston. I designed a chamber, sent it to CP, and they digitized it, and put it in a file for me, and it is only available to me. When I order a piston, it can be designed up to a max, like you see in the last picture, and that's as big as it can get.
It was $176 for each piston just to implement that design. Diamond now does that for much less. Both companies charge a few hundred bucks to do the initial head scan.
Yea please be sure to post that link when you get it again.
Discussion Starter #17
No prob, just ordered mine last night. For all the canadians on here, D&L performance out of quebec also carries them but they are out of stock on the 83mm pistons right now. D & L Performance
1 - 17 of 17 Posts
