1 - 20 of 29 Posts
Did it burn the exhaust valves? It wasn't running poorly??
Nova, my son has been riding it and was complaining that it was hard to start. I finally had time to check it out, went to set valve clearance and could not get any on one intake in rear head. Pulled the head and noticed dirt in the intake, I'm holding it apart in the pic but otherwise was very hard to see when mounted. Dropped the head off to machine shop and they phoned back once disassembled and cleaned saying I need 1 intake valve, grind the seats, valve guides and seals. I have a set of rings and gaskets here so will hone the cylinder and re ring while I'm at it. If you look at the pic the Orange rubber/urethane looks way to thin where it moulds over the alloy flange?
Is that the upp intake?
I had that happen to one intake of a pair of non-crossover UPPs for 36mm carbs.
Discussion Starter · #8 ·
That sucks butt.
Yes it does. I would advise anyone who has a set to check them before its to late. Very hard to tell anything was wrong with it because of the way it fits between the two heads but once some twist and movement is introduced like when on and off the throttle that's when you'll suck dust and shit in. If it was a single intake like twyztid is talking about it would be much more noticeable but the design of the x overs is a tight fit and the x over tube supports both intake runners.
Here is where mine cracked.
What I found is that the 1/4" thick spacers that most are using with the 36mm intakes are not thick enough. They should really be 5/16" thick. With only 1/4 spacers, the intakes stretch too much.
Are your intakes for stock carbs or 36mm carbs?
I will have to check mine sometime. My 700 has UPP crossover intakes on it.
Probably would never have that problem with the homemade ones done with Windo Weld. The area that cracked never gets touched when making them.
Discussion Starter · #16 ·
Yeah I sold the ones I made and fitted this orange junk, Sonic on here bought them and as far as I know they are still going strong....live and learn. But yes I would definitely check the UPP ones periodically to be on the safe side.
Did you get your orange ones used? They look pretty old. I think mine are red.
Discussion Starter · #18 ·
Nope brand new never fitted before I got them from a member on here. Prob about 3yrs ago.
Anyway I wasn't aware of any problems with them that's why I posted here asking John if he had heard of any. The main aim was to let others know so they can check theirs before any damage is done.
If you think that caused your burnt valve it's more then likely your own fault for riding it. I would think it would run poorly and backfire a lot..
Discussion Starter · #20 ·
If you read the whole thread you will see that I said my son has been riding it and was complaining that it was hard to start. He never said anything about it backfiring. I thought it just needed the valve clearance set, when I got around to doing it that's when I found the problem with one intake valve, pulled the head and discovered the intake had failed. Last time I rode it a few weeks ago it ran fine but like I said the way the intake is one piece you couldn't even notice it until it was off the motor. There was some dust in there so yes it was the reason the valve was trashed. Was it my fault? Hardly, I never made the intake! Anyway that's besides the point, the reason for posting as stated earlier is to see if John had heard of any others and to let other members know to maybe check theirs just incase.
1 - 20 of 29 Posts
