Does anyone have experience with Cvtech Trail Bloc primary clutch:)..alignment, shimming, braking? I have a 2004 Prairie 360, my primary clutch is shot.
There are a couple of clutch rebuilders (VForceJohn, Jim) on this forum that do a great job, and it should be much cheaper than buying a new clutch.
Vendor
outer plate bearing you can get from Dalton. but they are harder to install with the KEBC bearing. that's why kawy sells them with the plate.
I can get you a new updated spider and refurb your weights with new bushings for a little over 100.00
you will need a dealer to install the spider. you have to have the tools to remove the old spider.
I'd also replace the lower bushing.
