I'm replacing the clutch pack (secondary clutch) on my 1988 Bayou 300. The friction plates have tabs on the outer diameter which align with the clutch basket - some of these tabs have a small notch or indentation. Does it matter if all the friction plates are installed in the same orientation with the indentations lined up, or can I just put them in any way?
The manual does give that detail - just says to install them in the order they were removed - friction plate / metal plate / friction plate / etc...
Thanks!
Discussion Starter #2
Thanks!
Looks like it doesn't matter - I reassembled with no order and the clutch is working fine.
