Yes. Take the fork out..or the fork and actuator. I use a relay to fix the 2wd-4wd on the dash. Others use a DG6.
i recommend the dg6... it takes about 10 minutes to splice in and you never have to deal with it again.... and everything works like it should...
Products
If you take out/bypass you engine brake actuator, your dash will flash between 2wd/4wd. This will fix the flashing problem.
using the dg6 will also allow you to use a kfx 700 clutch cover instead of the stock one. makes for a cleaner look.
like they said everything works like it should and is really easy to install.
