Is there a issue with EFI brutes and certain cams? Someone was looking at cams I have listed for sale they are the Fundy trail/race cams. Latest ultimate grind that require the double springs.
I would like to know also? Will the cams that come with std bore kits work on efi brute?
John has my 08 with XX cams just waiting to get some dyno numbers and time on the machine!!!
With proper tuning you should be able to run any cam. I just installed a std bore fundy in an 09 brute and it runs like a champ.
How tuff is it to install the cams and pistons? I am mechanically inclined. What kind of power gains should i expect to see?
I will also be doing this in the near future.I hear it has good gains,I think mid 50's rear wheel HP. The problem appears to be getting it tuned right "flat spot on the low end". I will probably be using XX cams.
