Any good quality coolant should be fine. All are OK with aluminum now so..Prestone 50/50 is a good one. Peak also. If you buy the straight stuff remember to only mix it with distilled water..NOT tap.Anyone help me out with what engine coolant to use for my 2020 Mule Pro FXT eps LE? Thanks in advanced
Ok great, thank you!Any good quality coolant should be fine. All are OK with aluminum now so..Prestone 50/50 is a good one. Peak also. If you buy the straight stuff remember to only mix it with distilled water..NOT tap.
Right...some can actually gel when mixed together and heated. Not fun.Id personally be cautious about mixing types if your just adding some. Most of my water cooled stuff gets either the blue or red, import vehicle,dependent on what color it had to start. There all alum OK, but soem fo the types make a mess when mixed. Coolants have become a multi typed PITA.
