just put machine together, was in a rollover, low hour machine , had everything on machine working, lights, brakes, shifted perfectly, ran great, boys took for short ride down road, now when i hit headlight switch, the engine dies, have to turn off key and let sit for 30 seconds or so, then will start. checked the plugs and everything looked good, if i turn on key, the dash lights go on, but if i turn on headlights with out engine running the dash goes dead and won't start till i remove key and let sit. Its our first 700 and not sure about nuances of electrical system. the only thing I can think is maybe when routed the controls w ire was stretched or connector loose, I checked the one from the starter/headlight switch and it was a little loose.I clicked it.....but same problem. is there a breaker or bad relay? I have another complete electrical system and controls, just hoping someone has idea where to start. I just finished it (or thought so) and everything worked as it should ....thanks for any help....
-J-
-J-
