I took my carb. off today and when i did oil was in it. Then i drained the box on back of carb and there was oil in that. Just wondering if someone could tell me what is wrong and how the oil is getting there. thanks in advance to anyone that can help.
There's a breather at the back of the engine that runs to the airbox. If you recently spent a lot of time at high rpms, then that could do it. Or if you overfilled the oil, I know it sounds dumb, but I still have to mention it. Otherwise something is worn or plugged and causing too much pressure in the engine and blowing the oil out.
thanks for your help but i think i figured it out. i rolled it friday and i think that is probably what caused it. I have read that if you roll them that oil can run into your carb.
