1 - 1 of 1 Posts
BEST OFFER!!
The best all-around use kit; if you do a bit of everything with an ATV/UTV this is the kit for you. Great for trail riding, occasional mud and sand riding, plowing and hauling. Makes up for power loss and slow response of adding oversized tires. Designed to improve low- and mid-range acceleration. Helps decrease belt slippage, which will decrease clutch heat. Each kit will enhance back shifting and throttle response. Field tested to assure satisfaction. Designed for stock motor and exhaust. Elevation: 0-3000ft. Tire Size:27-28"This item fits the following models: 2008-2011 Kawasaki KVF750 Brute Force 4x4i .
This is a brand new clutch kit comes already assembled onto both the Primary and Secondary clutches. The clutch kit was never used. Selling it as an entire kit with a Brand New OEM Kawasaki belt and EPI clutch puller tool.
Save time and money on labor costs. This item includes every thing you need to simply install your clutch kit:
(1) Used OEM 2009 Primary Clutch --> $180. to $250. if sold separately
(1) Used OEM 2009 Secondary Clutch --> $40. to $105. if sold separately
(1) Brand New Kawasaki Clutch Belt - $98.99 if sold separately
(1) Brand New EPI Sport Utility Clutch Kit - 27-28" Tires - AW443102 - Assembled --> $259.95 if sold separately
(1) Primary Clutch Puller - PCP-1 --> $39.95 if sold separately
Fits:
Year Make Model Submodel
2011 Kawasaki Brute Force 750 KVF750D 4x4i
2010 Kawasaki Brute Force 750 KVF750D 4x4i
2009 Kawasaki Brute Force 750 KVF750A 4x4i
2008 Kawasaki Brute Force 750 KVF750A 4x4i
74612
74613
74614
1 - 1 of 1 Posts
