I just did the fluid change new belt front brakes found that the upper a arm bushings are bad called the dealer they said it will be covered so thats greatbut has anyone else had this problem..
The A-arm bushings wear out real fast. On both of mine I have installed Zerk fittings and seals on each end to try to keep the muck out. So far so good, I had to replace the bushings the first time between 300-400 miles, since the Zerks and seals, I've put about 1500 miles with no problem.
Get the Poly's from Kujo that is what I have done!!!
