If it's the same as a BF 750...what I do is take a small drill bit (1/8" or less) and a drill of course and be VERY careful to drill a hole centered on the plastic of the seal. Then use a coarse threaded wood screw and screw it into the hole, then pull it out with a vise grip or pliers. Just take your time on the hole- don't let the bit go IN to far past the seal....
