I replaced my front brakes this morning on my 2003 Kawasaki Prairie 650. The left side was no problem, and the right side wasn't any issue either except that when I first grabbed the brake rotor, it was was very wobbly. It's strange that the right side is completely sloppy and the left side is as tight as new. Could it be anything other than a wheel bearing? Any tips on replacing? Where should I get the part? Thanks for any advice.
The bearings are sealed and last quite a long time but if something come into contact with the seal and rips it water will get in .Once this happens the bearing will wear quickly.
Yea if the rotor was wobbling but not the spindle than it would be the bearing.
