1 - 9 of 9 Posts
This set has ten miles on it! Bought them for my old KFX but soon sold it for a new BruteForce. Finally clearing out the garage and selling things off. Stored in a climate controlled garage at all times. I will try to wash them and get better photos this weekend. 21x10-10 and 21x7-10.
$400 OBO.
IMG_7248.jpeg IMG_7242.jpeg IMG_7247.jpeg IMG_7243.jpeg IMG_6714.jpeg IMG_7511.jpeg IMG_7508.jpeg IMG_7512.jpeg IMG_7513.jpeg IMG_7514.jpeg
Where are you located?
Sent from my LM-G710VM using Tapatalk
What width are the wheels? 10x5 for the front & 10x8 for the rear? Those are pretty standard sizes. If they were the less common 10x6 & 10x9 sizes, that would be even better if I were to decide to buy them.
If you measure them, keep in mind that the width is where the tire sits... not the outer lips of the wheels.
I will try to measure them today. So basically from bead to bead?
Yes, that is correct. Might be hard to eyeball it though. It is also possible that the Douglas part numbers are stamped on the back side of the wheel near the bolt holes. It is usually a 5-digit number.
Discussion Starter #7
Yeah no part numbers on any of the wheels. Very hard to tell even with a measuring tape. Inside edge of bead, outside edge, middle? This is enough to make the difference. I definitely do not want to mislead you! Here are some pics with the tape measure touching the flat part of the wheels on each side. The fronts seem like 6" and the rears 8" looking at it in person, pics seem more like 5 and 8. I didn't request anything extra special when I bought them.
Those appear to be 10x5 for the front and 10x8 for the rear.
Discussion Starter #9
I tried to dig up a receipt to no avail. Assume the worst if you are interested, I wouldn't want someone to be disappointed!
1 - 9 of 9 Posts
