Fuel pump help
3574 Views 6 Replies 3 Participants Last post by  Camo Joe
After sitting for quite some time I attempted to get the old 02 prairie running again. It'll fire up with ether in the carbs, but not pull any fuel. I verified that everything is clear but it seems like the fuel pump is not pumping. I've got voltage to it but it doesn't do anything.
A couple of questions:
Has anyone replaced just the pump motor itself instead of the whole unit kawi wants 2 arms and 3 legs for?
Is there a cheaper aftermarket pump available?
Couldn't I just put an electric pump from napa inline and make it work?
Thanks!!
1 - 7 of 7 Posts
Vforce John (Interstate Motorsports) sells a kit to replace the brute vacuum operated pump .This should work on the prairie also.Contact him .He is a sponser here.
Thanks
Thanks greasemonkey, I'll check in to that.
Thanks!!
You may just pull it out ...........clean it ......turn the pump motor..........then try the volts.............save a lot of $$$$$$$$
Make sure its not a fuse , relay etc...................
camojoe,
I've taken the motor itself off and I have voltage coming to the plug for it that's inside the tank on the pump/guage contraption. I tried spraying and soaking the pump motor and putting voltage to it but I can't get it to do anything.
Try to turn the motor/ pump in some way to give a start it may be just stuck somewhat from sitting..........but it could be bad...........and Yep they are high dollar.........$467.00 about at Babbits.
You might run another thread to find a part out or a good used one someone may have ......... if its bad...............
You might "private message" Vforcejohn............he may have mod that would work or a cheaper crossover.............
1 - 7 of 7 Posts
