A solenoid is switch, it offers no circuit protection. The only reason to use a solenoid is so anything wired to your fuse box will only have power when the solenoid is ON.
There are circuit breakers that can be used like switch, but you have to remember to turn them OFF at the end of each use.
I would use a circuit breaker to protect the system (battery to fuse box) and solenoid (continuous duty) if there is anything you plan to hook to the fuse box that could be left ON (which would drain the battery)
